Become a 2021 AZXC Supporting Member just Click the Donate button.
March 2021
[7] 8 9 10 11 12 13
14 15 16 17 18 19 20
  • Dot Guests: 16
  • PitSnipe (Kyle): Kickofff Run pics coming soon
    February 07, 2021, 04:19:30 PM
  • PitSnipe (Kyle): Getting excited for this weekends trip.
    February 04, 2021, 01:43:28 PM
  • PitSnipe (Kyle): Kickoff Run has been updated
    February 02, 2021, 02:58:01 PM
  • Clifford3200: Thank you Rob
    January 29, 2021, 10:20:57 AM
  • pinchel (Rob): Site is working...any other issues please always reach out to me.
    January 29, 2021, 08:25:19 AM
  • pinchel (Rob): test
    January 28, 2021, 06:13:39 PM
  • PitSnipe (Kyle): Lets get it started.
    January 28, 2021, 02:48:04 PM
  • Clifford3200: Yes :)
    January 28, 2021, 10:27:59 AM
  • PitSnipe (Kyle): Thats super bowl weekend. Still wanna go?
    January 26, 2021, 10:51:32 PM
  • Clifford3200: Feb 6th works best, but I can work with the 30th as well
    January 21, 2021, 01:04:08 PM
  • PitSnipe (Kyle): Ted moved back!
    January 19, 2021, 11:09:18 AM
  • PitSnipe (Kyle): Or Jan 30
    January 19, 2021, 11:08:23 AM
  • PitSnipe (Kyle): How about Feb 6th?
    January 19, 2021, 11:08:07 AM
  • Clifford3200: When?
    January 18, 2021, 07:18:29 PM
  • PitSnipe (Kyle): Lets do it.
    January 16, 2021, 03:21:54 PM
  • Azfronty99: Only real plan that's come up!
    January 13, 2021, 08:10:03 AM
  • Azfronty99: Why not!
    January 13, 2021, 08:09:47 AM
  • PitSnipe (Kyle): How about running Big Horn Mtn in reverse and then run to the top of Harquahala?
    January 11, 2021, 04:59:31 PM
  • Azfronty99: Azxc is kinda dead so I guess we will see what happens
    January 07, 2021, 02:05:07 PM
  • Clifford3200: Montana Mountain was beautiful around this same time a couple years ago!!! I'm excited!
    January 07, 2021, 12:54:08 PM
Author Topic: 2" BL for about $70  (Read 6111 times)
WHPIVxterra
2" BL for about $70
« on: May 11, 2015, 03:08:00 PM »
I got this from robcarync over at Clubxterra.org.
Body Lift How To Install:
http://www.clubxterra.org/forums/showthread.php?t=2191
Body Lift Tips:
http://www.clubxterra.org/forums/showthread.php?t=9713
Body Lift How to Piece Together:
http://www.clubxterra.org/forums/showthread.php?t=2151
You need 10 pucks, and a bunch of nuts and bolts:
10 qty: 2" tall, 3" diamter off road body lift pucks
6 qty: 7/16" X 6" long thread pitch 14 GRADE 8 bolts
6 qty: 7/16" thread pitch 14 lock nuts (NOT nylon lock nuts)
12 qty: 7/16" washers
2 qty: M12 X 1.25 thread pitch X 180mm long GRADE 10.9 bolts
2 qty: M10 X 1.25 thread pitch X 160mm long GRADE 10.9 bolts
You may end up needing additional M12 washers for the two rear most body mounts...those are easy to find at any hardware store if you end up needing some.  On some Xterras, the rear body mount bolts end up being a little too long, so they are threaded all the way through, but the bolt head has some space between it and the lower half of the mount....a few extra M12 washers (or 7/16") can be used to fill in that gap to maintain pressure on the body mounts.
It should be noted:  For standard hardware (7/16"), the strongest grade bolt is Grade 8.  For metric hardware (M10, M12) the stronged grade bolt is Grade 10.9.  Don't get METRIC 8.8 confused with standard grade 8.  Metric 8.8 is slightly weaker than either of those.
Get the pucks from ebay...search
===>"Zone Offroad - 2x3 Bulk Body Lift Blocks (single) #3296"
For your hardware, check out
http://allensfasteners.com/
They have all the hardware EXCEPT the M12 X 1.25 X 180mm long in grade 10.9.  They do have that size in metric grade 8.8, which some people have used on here without any issue.  However, these bolts will end up holding the cab of your truck on to the frame...so I managed to source a set of M12s from a user on here...I believe they got them from:
http://www.metricspecialties.com/
All in all, you can get all the nuts/bolts/washers/pucks for ~75 bucks or so.  Read the How To though, because there are a few things you need to fix or modify along the way which can add to the "total cost" of doing the lift.
The xterra is a frame rail truck...suspension holds up two steel beams which mount all of the tires and drive train.  The body of the truck is bolted to that frame in 10 locations...where the body lift pucks will go.  The pucks just serve as a spacer to lift the body 2" off of the frame rails.  Essentially what you do is unbolt all of the 10 existing body mounts, place a jack on the bottom of the cab's pinch seam, and lift the body one side at a time, then slide the spacer in place, and re assemble with the new bolts (which are essentially stock bolts, just 2" longer).  You have to look out for anything that attaches to BOTH the frame AND body...IE:  power steering reservoir is mounted in the engine bay to the body, but the hose goes down to a pump on the frame rail...so you need to make sure you have 2" of slack or you will pull the hose off.  Also, your bumpers are mounted to the frame, but are made to align with the body...they need to be relocated/shifted upwards ~2".
If you have any more questions, let me know.  I just installed the body lift on mine 2 months ago.
-Rob
Offline pinchel (Rob)
  • Club Treasurer
  • "He who laughs last, laughs last."
    • robakapinchel
    • pinchel
    • pinchel
    • VinylTats
Re: 2" BL for about $70
« Reply #1 on: March 24, 2019, 07:42:07 AM »
Click here to see my rig.  Get your AZXC/AZTC/AZFC Forum Decals here  VinylTats!
Offline AZGeorge
    • George Toft
« Reply #2 on: March 24, 2019, 10:43:48 AM »
Every item he drags across his hood makes me cringe, thinking of the scrapes in the paint :)
2015 Pro-4X.  Full skid plates.  Sliders. ARB front bumper+10K winch.  SPC+OME front suspension with Moog ball joints. ALCAN rear springs +400# +3".  Front bumper camera & live display.  Molle panels.
>>>>> TotM: 07/16 03/17 10/17 07/18 02/19 <<<<<
SimplePortal 2.3.6 © 2008-2014, SimplePortal
